CarPlay & Charging Navigation
kort
'23 Lucid Air GT
Yes, you can use both CarPlay and Porsche navigation at the same time, I do it all the time
while you can use both porsche nav and car play at the same time, you cannot run a nav program via car play and porsche nav at the same time. it is one or the other. for example if I am running a trip on waze, then load a trip into the porsche nav the porsche nav will take over and waze will stop, the same thing happens if you are running a trip on porsche nav and then load a trip onto waze, then the porsche app will shut down. Both navs will not run simultaneously.
KensingtonPark
New York, NY
This was my experience as well and my understanding of the OP’s question.
Cpoarchy
Kentucky
1999 911, taycan 4s
So you use CarPlay navigation and Porsche navigation at the same time? I’d like to be able to use Google maps navigation and traffic while using Porsche Nav to advise on charging and precondition battery
Yes, I have used google maps and Porsche nav at the same time also
hifi239
Will
Yes, you can. First enter your destination in the Porsche navigation and let it figure out all necessary stops. Then activate the Porsche map on the center part of your dashboard. Next activate carplay on the PCM. Google maps is one of the car play apps in the carplay settings on my iPhone. So google maps should be one of the icons on the carplay screen.
To be clear, can you have both the Porsche nav and a Carplay nav active and navigating at the same time, or just displaying? I was not able to get active nav at the same time to happen. So there is there a special sequence? Sounds like you have to move the map to the "center part of your dashboard" is this the upper PCM? Or do you mean one of the widget views on the second page of the upper PCM? Or is it the center part of the circle tube display behind the wheel? Thanks!
TDinDC
Washington, DC, USA
I can run Waze and Porsche nav at the same time too . . . If you look closely you can see Porsche NAV on HUD too
Porsche Taycan CarPlay & Charging Navigation IMG_5732
Could this be region dependent. I have tried your instructions many times, but it will only work with one of them for me. As soon as I try to enable PCM it shuts down CarPlay nav app and vice versa
SteveGTS
Steve
Tesla M3P, Taycan on order
I had a 2018 VW Golf with the premium entertainment which probably shares some hardware/software, there was a sequence I had to go through to get the built in nav in the binnacle and Waze on the infotainment screen, I think it was built in first, start a route then start Waze but it was nearly 4 years ago so not absolutely sure other than there is a sequence to get it to work.
TDinDC
Washington, DC, USA
Just a quick update here. I have always been able to run PCM navigation and Waze navigation via CarPlay at the same time.
I am happy to report that recent updates to iOS, Waze, PCM (or a combination) had made it MUCH easier to run both at the same time in a very reliable way. Before, if some voice announcement came along, it could stop the PCM navigation. I'm happy to say that now both run very reliably at all times and you can easily switch back and forth between the two without either shutting off, or you can do as I do and display Waze on the center screen and the PCM navigation in the right tube and heads up display.
In the pictures, the difference are due to the fact that PCM calls splits in interstates "turns" while Waze just ignores them . . . It's hard to capture heads up display image, but if you look closely, you can see PCM guidance. Also, the PCM guidance is shown on passenger screen.
When no turns are near, the right tube shows the default setting, which in my case is media, but when you get closer to a required action, the right tube switches to navigation, which is less important to me personally because my heads up display shows navigation constantly.
Top picture shows PCM Nav in heads up display, default content for right tube because no action is near in the PCM Nav (in my case, default is Media), PCM nav map in center tube, and Waze via car play in main center display.
Middle picture shows PCM Nav in heads up display, PCM Nav in right tube since action is upcoming in PCM Nav, PCM nav map in center tube, and Waze via car play in main center display.
Bottom picture shows Waze via car play in main center display and PCM Nav map in right panel of passenger display.
Very happy with the new reliability
Porsche Taycan CarPlay & Charging Navigation IMG_3824
Porsche Taycan CarPlay & Charging Navigation IMG_3820
Porsche Taycan CarPlay & Charging Navigation IMG_3814
FredC057
Fred
Brussels
Taycan Cross Turismo 4S (2022), Fiat 500Ce
Hi,
Did something changed for you as well with iOS 18?
I wasn’t able to run both pcm and Waze navigation at the same time at the beginning in 2022.
Then somewhere in 2023 after an iOS update I could run both of if I started first Waze in CarPlay and then the pcm or the inverse, I’m not sure anymore.
Now that I got a new iPhone with iOS 18, it’s back to pcm stops if I started first Waze navigation on Waze or Waze navigation stops if I start pcm.
it’s annoying as I use pcm to preheat battery and see what will be my soc at arrival for the next stop and I use Waze for the navigation bit as it’s way better.
Now I might have to go back to stop CarPlay and use Waze o
chun
Taycan Turbo 2020, Cayman GT4
I'm surprised to see this has worked for people ever.
I could never run 2 navigations at the same time, be them any combination: PCM + Google Maps / Waze / Apple maps; never worked. Which ever is started 2nd would take over.
