How does your Taycan feel after 15-20K miles?
dtich
Southern CA, USA
'23 Taycan GTS;'12 Model S(sold); Aprilia; Triumph
Mine is 1.5 yrs with 15k miles using as DD. Lately I am noticing little vibration on steering when I drive past 80mph. Don't feel that under 80. Other than that no major complaints.
wheel balancing?
Raek
New York
Taycan 4S, E92 M3, Wrangler TJ
Only grievance is the small amount of rock chips I've accrued on the areas with no clear bra. There's not a lot, but I can tell you exactly where they are from memory and it haunts me every time I'm driving it.
Replika
United States
Ford Lightning
One minor creak from the front left suspension. Dealer thinks I'm nuts because you almost never hear it in regular driving but if you go over a speed bump off-center, it's very noticeable. Which I do every morning taking my daughter to school. But it's a minor quibble.
I'm just over 20K miles and everything else is tight. No rattles or anything like that. Really important because the car is ridiculously quiet.
Is that not normal everyday driving? I feel that a well-maintained car should not have a creaking suspension, especially a new car.
OzzieT
Oz
Sydney
2023 Taycan GTS
Tyres? Do you have Goodyear Eagles?
TDinDC
Washington, DC, USA
While I only have 5K on mine, my Taycan, like every Porsche I have owned, is built solidly and does not feel any worse for wear at all, nor do I expect it to have problems.
My other Porsche is now 18 years old, and it feels absolutely new. Now, I am obsessive about maintenance, and I even replaced every suspension part on this car this year even though it only has about 30K miles because the parts just normally degrade with time just like your tires do even if they seemingly have enough tread. So the minute I have any issue with any part (like a button feeling "gummy"), I replace it immediately so that car doesn't slide into a geriatric state. I would do the same with my Taycan if I kept it for this long, but doubt that I will just due to advances for EVs over time.
I also find that I have grown to love my Porsches even more over time, which is unlike nearly every other car I have owned. Other cars, like my previous Teslas, lost appeal over time as the novelty wears off and the flaws begin to take over my attention.
The Porsches to me are more like androids than iPhones: The iPhones are much more intuitive and easy to pick up right away, but customization is limited to achieve this goal. Like an android, it takes a lot more to get a Taycan "dialed in", but there is so many more things to learn, which can be hard since the manuals suck (I learn more on this forum about how the car really works than I can from very carefully reading the manual), but the ability to customize is exactly why it grows on you as you learn its tricks.
As far as how my Taycan feels, I can't tell you because I haven't learned how to listen for its perspective . . .
I have now 29500 miles on my Taycan. Still feels like new, no rattles etc. Car is better than new thanks to the major SW update last year. Some squeaks from a few panels interior, but I suspect this has come about when Porsche changed a lot of the Comms modules earlier. The last 10k+ miles have only had one problem with HPC charging! Most likely not a problem in the car, but due to a massive thunderstorm that likely knocked out all communications and power supply to Ionity stations. Car will be checked next week if there is a problem in the car?
Just changed the front tyres, due to a pothole damage.
But still on original rear Tyres except for about 5k miles winter tyres. Time for new ones there as well.
Changed from Eagle F1 Asymmetric 3 to Asymmetric 5 and they seem quieter.
feye
Shenzhen, Munich
Porsche Taycan 4S+ 2020
Still love it, but:
1. I wish it had some sort of self driving feature like the BMW iX I recently drove for a week. Innodrive was never offered in my market...
2. I wish it had a bigger battery with the same weight, 120 kWh would be perfect.
3. I wish the trunk would be a bit bigger, so I could fit in a couple of golf bags easier.
Vim Schrotnock
Vim
Cincinnati
30K miles and 3.5 yrs and it drives like the first day. One slight 'rattle' I noticed going over bumps was corrected by replacing the rear headrest. That's about it. Pretty good after the agony of the first couple months or so getting the software straight and communicating with NHTSA on the dreaded 'red wedding' light. The only other minor issue is I can't believe Porsche didn't supply the correct gage wiring on their charger, so it will overheat if it's hot out and I have it set to 40 amps. I've dialed it back to 36 and it's fine so far...?
4thPcar
Del Mar CA
Now that I understand what I'm doing…..
Crazycanuck
Seattle
Taycan Turbo S, 911, Cayenne Turbo SE, McLaren GT
23k miles. 2.5 years. No major issues.
Techwizard100
Naples, Fl
www.ev1consulting.com
2024 Taycan GTS ST / 2025 Macan 4 EV
10K miles and still solid. Not even one squeak or rattle.
16,000 miles and boy it feels as tight as new and just fantastic. Learning how the car responds in very situations makes it all the better to drive really love this car.
