iPhone 12 Overheating during wireless charging
BayAreaJay
Jay
Fremont, CA
Porsche Taycan Turbo S
I had the same problem with the mini. Its the size not the protocol. If you put the mini into the holder and then use your finger to pull/rase it up about 10 mm from the bottom of the holder, it will start charging.
Unfortunately that is not a solution, so I traded mine in today for a regular iPhone 12 Pro. I did love my mini!
The entire center console (almost everything about it) is a bad design. If Qi charging needs center-to-center alignment, designing a holder with an edge datum/alignment is just poor design.
In your case, you can also try to add a spacer at the bottom to touch the mini to prevent it from going all way down. A crappy solution for a crappy design.
RPSRPS
Richard
New Jersey / Vermont
'22 TAYCAN GTS / '25 RIVIAN RIT TRI / '19 RANGER
Has anybody had there IPhone 12 overheat during wireless charging ?, it has happen to me twice so far, both times the phone has been charging for just over an hour, the phone just shuts down, has a temperature gauge displayed and is extremely hot.
Thoughts ?
Have my 22 GTS for about a month now, and after trial and error (case, no case, console full, console empty, carplay, no CarPlay) I‘ve found my iPhone 12 overheating (very quickly - 20 minutes), only when connected with CarPlay. Had no issue without CarPlay. Anyone else?
JonS1234
Jon
Toronto, Canada
Taycan Turbo, Model S Plaid, Model X LR
Yup, same here. Takes about an hour or so and the phone (iPhone 12 Pro) over temps and shuts down. I bought this super short USB-C to Lightening Cable for the console, seems better - https://www.amazon.ca/dp/B07WVXGFCJ?ref_=cm_sw_r_cp_ud_dp_0WGF30EHY9F2VNBH99S8
pauloamore
Paul
SCOTLAND
Taycan C4SCT
My iPhone 12 Pro overheated on a wireless charge using CarPlay on a 1 hr drive today. CT4S.
Rainforest
Canada
Tesla Model X, Tesla Model 3 LR
Yes, I find my iPhone 12 Pro Max gets super hot after charging for an hour or so. Worried it will ruin the battery.
DerekS
Derek
Los Gatos, CA
2025 Taycan GTS
It has been my experience that the wireless charger heats up the phone faster than it charges. I've just resorted to a USB-C to Lightning cable.
I haven’t got my Taycan yet but if I have my iPhone Pro 12 Max on the charge pad in my current car it warms a bit but if I use navigation and traffic monitoring as well it gets very hot indeed.
It isn’t an enclosed space and has never shut down but gets worryingly hot if both charging and running an app which is continuously linked to the internet.
Charging whilst, I suppose, in standby and connected to the cell network it gets barely warm.
refazi
Refael
San Francisco, CA
Same issue with my Taycan, Audi Etron SUV had it even worse since they didn’t have a fan in the charger like the Taycan has, the fan is.not really effective in the Taycan anyway…
Im not sure why Porsche hasn’t recalled this part and redesigned it with the proper fan/vents
offplan
UAE
Taycan 4S , bicycle , my own feet
There’s a fan for the charger? Need to look for it now. This is a known issue with Porsche sales rep claiming that “proper placement” is required for optimal performance. Kind off impossible with the armrest falling down when not held up
refazi
Refael
San Francisco, CA
I see venting holes, I assume it also has a fan..
RPSRPS
Richard
Made me laugh! It is unbelievable that with all Porsche's technical and mechanical knowledge and the quality of their build, no one picked up on the fact that the armrest requires two hands to access at the same time the steering wheel could use them. There must be a lot of three armed German engineers out there.
gnop1950
Gary
Sierra Vista, AZ
2022 Taycan 4s
I might give the charger a try to see if I have the same issue (iPhone 12 Pro), but so far my normal habit, in all of my cars, is to plug in my phone at the beginning of a trip and don't touch it until I'm stopped for a break or at my destination. I mean I can do everything through the car interface, including voice commands, so it just stays in the center console plugged in.
I've found that Carplay, again on all of my vehicles, is more reliable when plugged in than while using Bluetooth.
kort
'23 Lucid Air GT
agreed, whomever had any part in the design of that armrest compartment cover should be dealt with severely.
fgwinn
Philadelphia
MY22 FBM CT4 (sold), MY23 EQS SUV (sold), MY25 E53 Hybrid
.....In your case, you can also try to add a spacer at the bottom to touch the mini to prevent it from going all way down. A crappy solution for a crappy design.
In order to align my iPhone 13 mini with the console charger I used a velvet pen sleeve stuff with a short length of foam caulk backer rod as a spacer at the bottom edge of the charger "slot". I never got any overheating warnings on the iPhone 13 mini, but quit using the Porsche wireless charger since I kept forgetting my phone in the car. I now use a Magsafe charger with a ProClip mount on the passenger side of the console.
MattW77
Matt
Derbyshire
Yes, absolutely, iPhone 12 felt, in the words of Alan Partridge ‘ hotter than the sun’
I’ve stopped using mine and just plug in a usb cable in and charge it from that!
my car is going in for a couple of recall bits in the next week and that’s one of the things I’m going to raise with them.
including..
1. Randomly I can’t link my phone to my car
2. I’ve lost the charging status from the Porsche app
3. The car a couple of times hasn’t started due to a ‘fault’
4. The 50+ kw DC chargers now won’t work on my car.
apart from that it’s a great car!! ??
