prj
- Jan 14, 2025
- Estonia
- Website
- www.mapev.net
- Taycan CT 4 - 2026
- #361
If the dealer needs to diagnose something and then there's extra faults present, it might slow down the diagnosis that's all.So no issues if i were to swap the ASG back to the original without clearing any faults before bringing it into the dealer? It won't trigger anything/raise any red flags?
I ask because I will be bringing it in for some work in about two weeks.
Thank you
For warranty purposes it does not matter, what matters is what is in the car at the moment that the dealer requests warranty work to be approved. So the "here and now" versus "what has been".
If you come in with a tuned module, then the "here and now" is the fact that the tuned module is fitted. All the modules in the tuning detection system also keep track of when they were reflashed and the cryptographic hashes of each software that was flashed, so that is why flashing the car to stock does not work to avoid the flag - once you flash the "wrong" software into the module, it is permanently flagged as having had invalid software in it and the car is flagged on the next check.
However, at the moment, even with a flagged ASG Porsche chooses not to refuse warranty service for the Taycan.
If you exchange the module, then there is no flashing history in the original module with incorrect software, and even if there are fault codes present about communication loss with modules, those are not relevant for the warranty check whatsoever.
Against swapping modules there is "component protection", but with that the module is essentially policing itself (causing the car to have almost no power and various errors to light up on the dash). So if you have a hacked/modified module, then you can make it not police itself anymore.
The ASG also does not really store mileage or VIN permanently, it just reads those from the bus when key on is triggered.
In the end, modifying the ASG can not damage the motors or the battery because the ASG is not responsible for any protection at all. It does not have such functions - any power limitations in the ASG are of commercial nature only.
