UK service & costs
Packyjoon
Lotus Exige S Roadster, Model Y
Nicely done! and great info ... The 'major' service is every 6 years when they replace pads - and possibly discs too.... :O
For us with PSCB/PCCB that's gonna hurt! ... that's when it could be worth investigating an accredited indie and potential impact on warranty/history etc....
:surprised:Jes… is it mandatory even with 60+% left on these PCCBs?
smoothound
Alan
North West UK
CT Turbo Acid Green PTS
Not 100% sure with PCCBs, but the pads are mandatory on PSCB at 6 years regardless of wear - It's an age thing - 6 years max allowed under warranty if you want an official service.... I assume same for PCCB.
tophamn
Neil
Bristol UK
Taycan ST GTS (gone); Taycan Turbo-S ST
I sincerely hope not - the Taycan hardly uses the mechanical brakes so the wear will be minimal. The cost, however, will not be 😲.
Maybe it's an excuse to change the car before 6 years... 😉
smoothound
Alan
North West UK
Absolutely agree about wear .. But it's in the published maintenance schedule - Will be a lot cheaper at an accredited indie, but need to consider any warranty and resale history implications (if any).... Discs are not mandatory thank goodness (10k+)! They depend on inspection..
..........Every 6 Years / 60,000 MilesIncludes all basic 2-year service items.Additional Work: Replacement of brake pads (regardless of wear) and battery coolant checks.
See attached....
Boer13
Jaco
Taycan 4S & Macan S
6 year service quote received today:
Standard brakes on this one -
Porsche Taycan UK service & costs 1780524096169-51
Mr AI suggests:
Therefore, if you have standard brakes, your total out-of-pocket invoice at a main dealer will likely land between £1,800 and £2,400. If you have PSCB or PCCB upgrades, the total bill will hover closer to £5,500 to £5,800.
:0
Vespercooper
Scott
Edinburgh
Taycan Cross
If you’re heavy on brakes 100-130mph. Is this normal brakes or electric that slows you down quickly. I notice the first hit on the break at these speeds can be very slow to react.
Packyjoon
Interesting - In my experience if I am going like 70mph and hit the brakes hard-ish to slow down say for a round about in sport mode, I’ve notice the car usually use 100% brake and not regen at all. I’d say this happens like 70% of the time.
Murph7355
Andy
The car uses regen for braking most of the time AIUI.
Exceptions...
  • A short period (a mile or so IME) when using the car after it's been stood (overnight IME)
  • The last 12mph or so of braking (may be a bit less) when it transitions from regen to hydraulic
  • When the battery is 100% charged. You may get a small period when the hydraulic brakes are used (though tbh IME this coincides with the first point generally.
Other than that, my understanding and experience (looking at the power meter) is that regen is used.
mandoyoda
None
Service quote for my base Taycan 2021 is for £1,084.24. It seems expensive compared to the first service, which was around £500.
Is this reasonable, or should I look for an Indie in London to perform the service?
Porsche Taycan UK service & costs Screenshot 2026-07-21 at 12.45.14
mandoyoda
None
I got a quote for £516 from an independent. I have a Porsche extended warranty on the car, so does anyone know if servicing the car with an indie voids the warranty?
Price is about right if 40K / 4 year service. Same cost for a Macan ICE and seems the entry point for any Porsche these days.
My first Taycan service was £650 at 2 years but servicing costs have now rocketed due to excessive labour rates.
What's not listed is the mandatory brake fluid change at 2 year intervals so likely that work will have been done too.
Servicing Porsche EVs is costly compared to BMW.
Warranty may be impacted.
Leccy61
Yeah, line item prices just a little higher than what I paid Porche Reading in Dec ‘25. Skipped the brake fluid change because the brake line recall had been done relatively recently. Might be worth asking about that as they don’t seem to skip anything without being questioned!
mandoyoda
None
Thanks - that's a good idea.
